try one of these:
Thought I'd try the cheapo way to fix my signal switch.
Here's the broken original in place:
and here's the two side by side:
They look identical, almost. The replacement cam is more cheaply made and the little spring strips don't fit as well as on the original.
Finally got the cam on the old switch, even soldered and shrink wrapped the connections.
Put everything back together and guess what? No brake lights, no signal lights, no cancelling for the left turn. After 2 hours of electrical troubleshooting and taking it on and off again, I gave up frustrated.
But luckily I had one of these:
Found you had to take the connector off the old and new, to remove the old and thread the new wiring down the column. Needed to lower the steering column and remove the clip-on wire protector on the column:
Here's the original harness connector with the new wiring:
The little individual connectors come out of the harness connector fairly easy with a small screwdriver prying on the sides of the connector.
Here's the replacement in place:
Took two hours and with everything reassembled, the replacement switch works just fine, just like the original when new.
Moral of the story: Don't try to repair a 67 signal switch, just get a replacement.
#42179
#42179
