I'm in process of restoring a '70 BB chassis / suspension and am trying to get bolt finishes correct. Does anyone knows correct finish for these:
- u-joint clamp bolts
- camber bolt / washer / nut
- bolts and stover nuts to hold upper control arm shafts to the frame
- upper and lower pivot bolts, large washers, and lock washers
- spring end bolts, castle nuts, and large washers for bushings
- fuel tank cross member mounting nuts, bolts, and washers
- fuel tank strap bolts
- bolts and lock washers that mount to top of pumpkin
- bolts to mount vacuum cannister and brass radiator overflow
- bolts and frensh locks to mount half shafts
- bolt, nut, spacer for under chassis E-brake plastic roller ass'y
- resr sway bar / bracket mounting bolts, nuts, washers
I can guess based on finish (or lack there of) left on my bolts, but they are fairly rusty and I am not sure if I am seeing any signs of cad plating or phosfate 'sparkles' even after cleaning the h/w above. Steve
One low mileage 1972 has red "ARMCO" printing on the backing plate, so it is a cousin to road barrier.
