About 3 weeks ago, I had a post and thread about no brake lights or hazard flasher lights. This was after I had gotten stuck on the road, and had had the hazard flasher on for about an hour and a half. Thought I'd update you guys on the outcome.
After numerous hours of trying to chase down the problem with a volt-ohm meter, the more immediate solution was simply to replace the turn signal switch. So I ordered a replacement one and after I received it, a couple of hours later, everything works just fine.
However now that I have the switch out and on the bench, I figured I'd track down what was exactly wrong with this switch. The switch in question is a replacement switch which replaced my original about a year and a half ago.
So I tracked down all the circuits in this switch and I pinned it down to the turn signal cam which distubutes the power to the various signal lights. I had continuity to the top of the cam for rear brake and rear hazard lights, but no continuity to the rear light feeds.
So I removed the cam from the switch by prying out the pivot from the rear of the switch. This is what it looked like with the cam removed and flipped over:
At first look, one would think it was the dirty and worn contacts in the switch itself, but on closer look and test with an ohm-meter, the real culprit pops out:
See that melted plastic at the connection of the top wire tang at the center. The melted plastic basically insulated the tang from the brake line connection which comes in the top of the cam. Just can't believe that leaving the hazard flasher on for an hour and a half could melt the plastic at this connection. Perhaps it was a manufacturing defect from the beginning, but the cam did work for about 18 months.
Here's my original cam for comparison:
You can probably guess why I replaced my original switch.
So now I'm scratching my head for a fix. Maybe a little screw and a washer or tang to bridge across the melted area. Maybe a new cam.
I have researched the replacement cams. I think most vendors have stopped selling the cam repair kits as they do not work. There is nothing I have found exactly like the original cam in configuration and thickness. I have tried a few.
You might see a Restorer Story, once I figure this out.
Having fun,
Having fun,
. Replaced it maybe a year ago with a switch purchased at the local Chevy dealer and it is working fine so far
. Of course the General gets a bit more $$ for his
