Restoring An Original C2 Fan Clutch - NCRS Discussion Boards
  • Joe S.
    • April 1, 1996
    • 28
    I have an original, 67-dated big block Schwitzer (bar-type) fan clutch that unfortunately, was stored face-down causing the fluid to leak out of the front plunger. Referencing "Fan Clutch Cool Down" (Restorer Winter 1991) and "Corvette Fan Clutches" (Restorer Spring 2005), it would seem that you could refill the reservoir by removing the rectangular bimetallic plate and brass actuator plug, depressing the valve and refilling the reservior with a high quality silicone hydraulic fan clutch fluid (Toyota Part number 08816-03001). A variation of this procedure is well known for the sealed Porsche 928 fan clutch. See http://www.nichols.nu/tip482.htm
    Has anyone ever tried this?
  • Pat K.
    • November 1, 2003
    • 351
    Re: Restoring An Original C2 Fan Clutch
    I'm sure Fred Oliva can answer your question. He does clutch fan restoration.
    foliva@gate.net
    954-755-1161
    • Joe S.
      • April 1, 1996
      • 28
      Fred was quoted at the bottom of the thread on the weblink in my first post as saying:
      "The biggest problem with the procedure described is getting the correct amount of fluid back into the clutch. The best way to determine this is to add about 5 cc of fluid with a syringe as described, and then test to see if the clutch functions. If it does not, add another 5 cc & repeat. The basic test for function is to shut the engine down at idle & observe the fan. It should stop within 3- 5 revolutions of the engine stopping. This process is labor intensive, but it is the only way to get the correct amount of fluid back into the clutch. The caveat here is that if the clutch was low on fluid, the ceals are probably bad & the fluid will leak back out in a short time."
      Mercedes also uses a bar-type clutch that is refillable with a similar procedure:
      I have attached pictures of the Corvette-Schwitzer, Porsche and Mercedes clutches for comparison.
      In addition to the Toyota silicone hydraulic fan clutch fluid (#08816-03001), good quality silicone oils are also available from NAPA and from hobby shops for use in the differentials of radio control cars. Here is a link with great pictures of how to refill the Porsche fan clutch: http://members.rennlist.com/blueshark/page12.html
      I will attempt to refill my clutch using this procedure and will update this thread with the results.
      • Joe S.
        • April 1, 1996
        • 28
