Corvette steel wheels - NCRS Discussion Boards
  • Paul W.
    • July 15, 2009
    • 21
    Does anyone know where to find five 1 5/8" valve stems and dill caps for a '65 corvette with steel wheels?
  • David S.
    • August 9, 2009
    • 595
    Re: Corvette steel wheels
    The valve stems and repro dill caps can be bought from Long Island Corvette Supply. If you want original dill caps I have some. PM me if interested.
    -Dave
    • Paul W.
      • July 15, 2009
      • 21
      Dave,
      I am interested. Please call me at 409-651-2381.
      Thanks Paul
        You're gonna be mighty disappointed if you put 1_5/8" valve stems on '65-6 steel wheels. If you do, you'll need to remove the wheelcover every time you want to check pressure or add air. The stem cap will be down in the hole, below the surface of the cover.
        The '65 TIM&JG should have said 2" stems. Maybe for the KO's, the shorter stem is TFP, but not the standard wheels.
        Big pics show a 2" stem and with the wheelcover on (notice protrusion). This particular JK rim has a 3_65 production date. Thumbnails show the inside with what I believe is the original stem. TR-418 2" stems are still available; maybe not through GM, though.
        I'm sure Mike Murray has this already in his file for the next updates to the '65 manual.
        • David S.
          • August 9, 2009
          • 595
          Originally posted by Kim Cohen (3999)
          FYI we sell original dill brand caps - they are not repro - Long Island.
          listed in catalog section 46 part 22...
          Thanks for the info Kim. Did not realize it.
          -Dave
          • Michael M.
            • February 1, 1993
            • 605
            Wayne you are correct, from the top of the rim to the top of the stem should be 2". On the bottom of the stem should say TR-418 Schrader USA as per Nolan Adams book page 265. And of course the Dill 627 slotted cap. If anyone needs the stem, cap, and correct wheel weights please send me a message.
            • Jim R.
              • June 30, 2001
              • 643
              I have been told at a ncrs meet that the 65 also used the schrader caps not the dills "schrader henstooth caps"
              • Jeff A.
                • January 1, 2000
                • 312
                try these ---> http://cgi.ebay.com/ebaymotors/64-65...mZ200394204563
                My Cars
                • Paul W.
                  • July 15, 2009
                  • 21
                  please e-mail about valve stems and dills thanks Paul
                  • Dale S.
                    • November 12, 2007
                    • 1224
                    TR-418 is also a Milton Mfg Co. number. D/
