Big Block Valve Covers and Bolts - NCRS Discussion Boards
    • 1822
    I'm in the process of "judging" my engine because I'm starting to assemble the parts I need to eventually put it together. In the judging guide (JG), it says "the surrounding outer lips on original covers have a minimal flat area."
    How wide is minimal? On the inboard side, the flat area is about 3/8 " wide on mine (that doesn't include the seam, 7/16 " if you do). The outboard side flat area is about 5/8 " wide.
    Here's another quote from the JG, "Each cover typically is secured with seven recessed 7/16 " hex head bolts... Late production cars may have flat 7/16 " hex-head bolts." My car was born on May 24, 1966.
    What do the recessed head bolts look like? How about the flat hex heads?
    I have enclosed some pictures of my parts. Do I have the good stuff or what?
    Thanks in advance,
    • 1822
    Re: Big Block Valve Covers and Bolts
    Here's the bolt pictures.
      • 43259
      Joe------
      These bolts are the "flat head" style. Actually, these are called "trimmed" head bolts. Considering the headmarking and the build date of your car, I'd say these are likely original bolts.
      By the way, if the judging guide calls these bolts 7/16" bolts, then the judging guide is incorrect in terminology. These bolts are 1/4-20 bolts which use a 7/16" across-the-flats wrench size. Bolts are described by the thread size, not the head size.
        • 1822
        Joe------
        Thanks for the info! That was what I was hoping to hear. I was quoting from the JG. I didn't think about it until you mentioned it, but you are certainly correct. They should have said 7/16 " head maybe, but even that isn't the usual practice, like you said.
        • John C.
          • 616
          The lip the judging guide is referring to is very very small. Most reproduction valve covers don't have it. It looks like your valve covers have it but it is hard to tell from your pictures.
          The two pictures below show it. First picture is a valve cover with the lip The second is without.
          John
          • Ronald L.
            • October 18, 2009
            • 3248
            Joe if your car was a little earlier it would need a dent in one of these covers and that was the way for many years to avoid the repro junk, they didn't make one with the dent. Fortunately I have the originals even though its' late to the JG on when that dent went away, I'm not changing a know original part.
              Just curious... does the 66 JG mention that the indented head bolt on early cars is 3/8" wrench size instead of 7/16" ?
              • Joseph T.
                • March 1, 1986
                • 169
                Hi Joe,
                I have an early June 1966 and it utilizes the same 7/16" Flat Bolt head w/ "RBW" Headmark attaching the Valve cavers.
                  • 1822
                  Michael,
                  No, what I put in quotes is exactly what the JG says, 7/16 " for both styles of bolts.
                    Michael,
                    Pretty sure the early (first few months of production) valve cover bolts had a 3/8" hex head. In fact I'm sure of it. Same bolt used for the 65 396 covers.
                    I think the reproduction bolts with 7/16" dished head may be incorrect.
                    I don't remember a 7/16" hex head with the same dished style.
                    Does anyone have an early car with original bolts?
                    I remember this same discussion here a few years ago and Dick Whittington agreed that early 66 cars had the 3/8" hex bolts with dished head.
                    • Harvey S.
                      Infrequent User
                      • May 31, 1999
                      • 24
                      Guys:
                      Just checked my value covers and bolts on a Sept 65 BB. Value covers have small lip and bolts are 3/8" hex.
                      Hope this info helps.
                      1966 427/450 Coupe
                      Duntov Award
                        Originally posted by Harvey Schutzbank (32284)
                        Guys:
                        Thanks Harvey. I think some of the guys were starting to think I've lost my memory.
                        I'm not sure if a 7/16" hex with the lip was ever used on any 66.
                        • Ronald L.
                          • October 18, 2009
                          • 3248
                          Michael,
                          I digging through buckets of orange bolts, small 3/8 indented head and flat head 7/16 predominate - no to the one you haven't seen. I see several variations of head marks, RBW, TR, and then some D, A and others that to me are a 70's thing such as the blue bolts are a sure give away to the later vintage.
