67 big block info - NCRS Discussion Boards
67 big block info
  • Mike E.
    • February 28, 1975
    • 5153
    67 big block info
    This mid-year illiterate (but reasonably experienced with 62 and earlier) guy has a friend who wants me to go with him to look at a 67 coupe big block with air. Non-original motor. What are the tell-tale signs for a big block car vs. small block. I have almost every judging manual except 67, so my apologies if this is something that's overly obvious to everyone else.
    Thanks!
    Mike
    Re: 67 big block info
    Large copper radiator, no surge tank, rear antisway bar, no 5500 rpm tach, boltd rsther than uclamps on the u joints at the stub axles on the rear differential, look for original hood, protectoplate? and oh yes, must be red and a convertible!
      I think the BB steel fuel line along the RH frame rail also extends farther forward than on an SB. Since this fuel line is not easy to change w/o removing the body, it can be the best sign that the car is not a made up BB.
        • 8409
        bb + battery cable has extra "J" clamp on pass side firewall. 3 instead of 2 as in sb's. mike
        • Ed Jennings
          speaking of the battery, it will be located on the left side with an access plate in the fender well for removal. This is also true of SB cars with A/C.
            • 8409
            would your friend be the 13th apostle? regards, mike.
            • Tim G.
              • March 1, 1990
              • 1424
              Should not be an AO Smith body, they never got the stinger stripe correct so only small blocks came from this plant. Could be an exception if a very early car.
              • Jeffrey S.
                • August 31, 2000
                • 33
                I disagree with Bill. Must be Marina Blue and a Coupe.
                Jeff
                • Ed Jennings
                  Please disregard this post, senior moment. Applies to 65 MY only.
