GF-90 Fuel Filter "Eeny, meeny, miny, moe" - NCRS Discussion Boards
  • Jim V.
    • November 1, 1991
    • 587
    Let's dance on the head of a pin again boys.... I am currently going through some GF-90 hell for a 65. Been researching and ordering and have collected an expensive sampling of currenly available options...
    Options A (Paragon), B (Vette Prod. of Mi), and C (Long Island)
    Personal observations....
    1-Option A is longer which will make for a better fit.
    2-Options B and C have grooved nuts as specified in current 1965 TIMJG.
    3-Option B has an elongated circle around the AC.
    4-Option C is very glossy and has a markedly smaller font.
    Help...Care to comment??????
  • Alan D.
    • 2046
    Re: GF-90 Fuel Filter "Eeny, meeny, miny, moe"
    Just to add some more;
    This was purchased in early 70's so its not a repro, but a service replacement.
    My understanding at least for a 64 car is that no groove should be seen. These are available from somebody (not sure who) Don't think a judge would hit you if it was a little long, but will get hit if grooved (on a 64 at least)
    • M W.
      • July 31, 2001
      • 835
      Jim, I went through the same thing awhile back while having my car Regionally judged and found the ones that are sold on ebay for approx. $40 are the best ones. The fellow out of Maryland who sells these spent a tremendous amount of time and money developing these and as you can see from the pictures are dead balls accurate. Remember this is just my two cents worth.
      Cheers,
      Craig
      • Jim V.
        • November 1, 1991
        • 587
        Craig...believe the Corv. Spec. of Maryland is same as item A pictured (Paragon).
        Seems the grooved nuts started to appear in 1965 and is specifically called out in the 1965 TIMJG.
        • M W.
          • July 31, 2001
          • 835
          Jim, you could be right on the grooves. As for my 64 it was exactly what I needed. Good luck.
          Craig
