brake spring on 63 - NCRS Discussion Boards
brake spring on 63
  • Joe C.
    • April 30, 2001
    • 126
    brake spring on 63
    I had my 63 judges recently at Boston Regional and I was told by judge that I was missing front brake spring. he didn't elaborate- I have no idea what he could be talking about? Where is there a front spring on front wheel that a judge would see? any help to clarify, I lost 2 points. THANKS
  • Harry Sadlock
    Re: brake spring on 63
    Joe, try to find out what spring... Also, do you have power brakes?
    Harry
    • Tracy C.
      • July 31, 2003
      • 2739
      Around the circumference of the front brake drum there should be a flat wire spring approximately 1/2 inch in diameter.
      tc
      • Joe C.
        • April 30, 2001
        • 126
        I have power brakes, I have no idea what spring.
        • Joe C.
          • April 30, 2001
          • 126
          I know this spring went around 62 cars drum - to quiet vibrations- Did it also have it for 63- ? are you sure?? and with tire on how could a judge see if it was on drum or not?
          • Tracy C.
            • July 31, 2003
            • 2739
            Yup, I'm sure. Judges could reach in from behind with fingers to feel/detect presence of spring.
            tc
            • Joe C.
              • April 30, 2001
              • 126
              thanks- can I get these from say a Long Island Corvette Supply- or is it something I have to hunt for?
              • Tracy C.
                • July 31, 2003
                • 2739
                Not sure but I think the repros and service replacment parts from GM are a smaller dia with round wire versus flat. I think the 63/4 passenger cars also used them so finding a pair shouldn't be too hard.
                tc
                • Joe C.
                  • April 30, 2001
                  • 126
                  THANKS AGAIN, BECAUSE i CHECKED AND lONG iSLAND cORVETTE ONLY HAS ROUND SPRINGS, BUT pARAGON HAD THE FLAT- mY NEXT QUESTION IS do they go on all four wheels or just the front???
                  • Tracy C.
                    • July 31, 2003
                    • 2739
                    There has been debate here before on this question but I believe they should only be on the front.
                    You may find something in the archives or others may jump in with there opionions too.
                    tc
                    • Joe C.
                      • April 30, 2001
                      • 126
                      well, it would seem to be 2 of them ( now that I think about it)because I lost 2 points , probably one for each wheel, so at least for the Regional in Boston the opinion was 2 springs- thanks again for your help.
                      • Alan Drake
                        Re: brake spring on 64, both front & back ?
                        Just to add to confusion
                        I have a Mar64 with round springs on back (both wheels) and a flat spring on drivers front wheel.
                        What section of JG is the spring in??
                        The 71 Parts Cat calls for 2 springs on the 63-64 w/SP H/Per, pn 3776935 on the rear. Bet these numbers changed a few times before the end of 63/64 production run thus yielding a number for flat and a number for round.
                        Does anybody know the dimensions of these, width of flat and dia of round?
                        Good luck with your search and I'm off to do a search of the real story.
                        • Alan Drake
                          Re: Maybe J56 item
                          The 3776935 may not be the spring going around the drum, if not could it be for the J56 option? Think Duke can answer this one.
                          It does not appear it is anything else than the spring that goes around the drum since a spring is used for 63-67 pn 3694290 on all cars except Sp.H/Per. My car is a Sp.H/Per with the J65 brake option and has springs therefore I believe a Sp.H/Per car did have springs and the only number left is the 3776935.
                          Hope somebody can help!
                          • Joe C.
                            • April 30, 2001
                            • 126
                            well it seems in talking to Paragon and Long Island corvette supply, that 63 had a flat spring and 64 had a round one. Each of them told me that they really weren't sure whether it was the 2 front or both. It is pretty well decided though that there are definetly 2 on the front. its whether there are 2 on the back as well. I don't know because in my 1963 assembly manual I couldn't find any reference to a spring anywhere on any wheel drum. Its a bit confusing. But as I wrote earlier, I was deducted 2 points at the Boston regional for not having them on the front and there was no mention of springs on the back wheels or any point deduction taken.
                            • Alan Drake
                              Re: brake drum spring (external)
                              OK, do a search of "brake drum spring (external)" posted by ian #32567 on 6 March 2000.
                              Good discussing and data from Duke (knew he had some info on subject)
