C2 63/64 grille hardware - NCRS Discussion Boards
  • Alan Drake
  • Alan Drake
    • Frank C.
      • January 1, 1986
      • 277
      Re: C2 63/64 grille hardware FYI
      Alan... if your refering to the brackets on the front f/glass panel, both of my 63's are rivited. Not sure of my '64. Be happy to look at them and let you know if you wish....Regards Frank
      • Alan Drake
        Re: Locations
        The subject nuts and screws are used to hold the grille onto the body. There are the 3 along the top between the headlights, 7 along the bottom behind the crome finsih, (all ten are part of fiberglass panel) and the two remaining go into a metal mounting bracket that is riveted mid way up on either side just above the parking lights.
        Not aware of what the first 63 design looks like, however a look at your 64 should make my description clearer.
        • Frank C.
          • January 1, 1986
          • 277
          Re: Locations
          Alan....I didn't mean to confuse this issue, I thot we were talking about the brackets on the front of the inner fender panel. But if you wish I'll look at them tomorrow. I had an issue myself today with my dog and a raccoon that decided they didn't like each other. ($800 vet bill)
          • Alan Drake
            All set with question, thanks! *NM*
