Ive got #1800 or so 1968 (convertible), and it's got some unique parts that's for sure! Here's an interesting question:
There are two stainless pieces across the top of the windshield. One is the wide piece that the convertible top w/s sits on, and the other is the narrow piece (windshield trim) that actually covers the top edge of the windshield. The windshield trim piece I think is original, the wide piece I know is not, although it is not a repro. Problem is, they don't fit together. There is a flange that sticks out on the wide trim piece that's about 1/8" wide across the front edge of the trim, and has six notches, each about 1 1/2" wide evenly spaced across the length, too. This flange prevents the windshield trim, whose rear edge is solid except for six ~1" notches, from coming up flush against the wide piece. I assume that maybe the wide piece didn't have the flange on early '68. I'm not sure what to do. Here are some possibilities:
1) Can I modify the wide piece to fit flush against the narrow piece? If so, how can I modify it to make it as close to original early '68 as possible? 2) Should I just buy a new windshield trim to match my existing (probably later model) wide trim piece? 3) Could I locate an early '68 wide piece that will fit against my existing correct windshield trim?
Any ideas or suggestions (i.e. why are you so dang londwinded?) would really really be appreciated!!!!! I bought my car as a basketcase and it's been a heck of an ordeal piecing it together!
I'll try and post a picture of the offending pieces if anyone wants to take a look: and trim2.jpg. Check out corvette.jpg while you're there.
THANKS! Michael
THANKS! Michael
