Fail PV if high-pressure oil pump?? - NCRS Discussion Boards
  • Michael W.
    • April 1, 1997
    • 4290
    #31
    Re: Fail PV if high-pressure oil pump??
    Originally posted by Bruce Wilcox (29338)
    Mike, funny thing I brought the car two years ago to PA and failed the PV but it wasn't for that. Tim never said anything about the oil pressure and he did the whole test. I don't remember the pressure being that high? I wonder I changed the oil and put in 30 wt. valvoline racing oil. I wonder if that oil could be making it higher? your thoughts? would it hurt the engine to put 10w30 in it?Bruce
    You're not helping the engine by putting a straight 30 weight oil in it not does a 'racing oil' have any use on the street.
    • Mike M.
      • May 31, 1974
      • 8382
      #32
      i run rotella 15/40 in all my sbc and bbc engines. mike
      • Bruce W.
        • June 30, 1997
        • 358
        #33
        no it is a 60 lb guage
          • 43219
          #34
          Mike------
          YUP! I absolutely do not recommend the use of single viscosity oils for a street Corvette. That was OK back in the 60's and 70's but definitely not now.
          • Bruce W.
            • June 30, 1997
            • 358
            #35
            Mike, I have had the pan off before but never changed a pump. does it have to come off the engine? any thing I should be aware of? torque specifications?Thanks, Bruce
            • Bruce W.
              • June 30, 1997
              • 358
              #36
              does that have zinc in it?
                • 43219
                #37
                Bruce------
                If you mean does it have to come off the engine to change the relief spring, the answer is no. However, you should have no fear about removing the pump anyway because one bolt and it's off. It couldn't get much simpler.
                  Bruce -
                  Absolutely! CJ-4 15W40 oil has more than adequate zinc/phos (ZDDP) concentration to provide protection for any OEM valvetrain. Get rid of that straight-weight oil - it became obsolete 40 years ago (and stop listening to "engine-builders").
                  • Jerry B.
                    • August 31, 1994
                    • 416
                    #39
                    What would the best choice, rebuild original old style "thick" housing", or going with a new GM. Does anyone know if NAPA stocks the correct Melling thick housing ?
                    • Michael M.
                      • September 1, 2010
                      • 118
                      #40
                      Sorry Bruce. I was responding to the original poster, Stephen, who said his gauge was reading 70-80 lbs. It should read 60 max. Not sure what you have or what's correct for a 58.
                      Mike
                        • 43219
                        #41
                        Jerry------
                        Use a Melling #10553 and install the yellow spring that's supplied with it.
                        If you have an original pump it might be OK, as-is. Open it up and note if there's any wear on the bottom plate. Then, check the gears for scoring. If it checks out, it should be OK for re-use. Oil pumps are well lubricated (to say the least) and often suffer little wear even at high mileage.
                          • 43219
                          #42
                          Mike
                          Mike---
                          All C1 used standard pressure oil pumps.
                          • Michael M.
                            • September 1, 2010
                            • 118
                            #43
                            Mike---
                            Thanks for the info Joe. I was responding to the OP about his '66 L79. But I always learn a lot from all the posts I read. Now I know a little more about C1 motors. I know that some of the C2 fuelies and solid lifter small blocks had 80lb gauges. Did they have higher pressure pumps as well, or just higher reading gauges? And did the later C1 fuelies and solid lifter motors, like the 62's, have the standard pressure pumps?
                            Mike
                            • Jerry B.
                              • August 31, 1994
                              • 416
                              #44
                              As always, thanks Joe.
                                • 15599
                                #45
                                Bruce,
                                You will find the needed torque specifications in your copy of the Chevrolet Overhaul Manual for your year Corvette.
