C2 dash cluster bulbs LED - NCRS Discussion Boards
  • William K.
    • April 1, 1990
    • 37
    Anyone replace cluster bulbs with LED bulbs? What bulb did you use? Does anyone sell a kit? Happy with the results?
  • Steven B.
    • June 30, 1982
    • 4000
    Re: C2 dash cluster bulbs LED
    I have not used them but these folks advertise your application: http://www.superbrightleds.com
    • Scott M.
      • January 1, 1996
      • 216
      I used a couple different LED bulbs from superbright and I am very happy with the bright, white light I now have and the brilliant green for the heater controls. WP_20130417_001_zpse91738b7.jpg WP_20130318_004_zpse1e2ded6.jpg A 9 LED green bulb for heater controls. I had to slit the torpedo holder down the middle and remove the green plastic cap for it to fit .WP_20130417_006_zpsbf04b5cc.jpgWP_20130417_007_zpsec3a5845.jpgI'm using the flat 6 LED lights in dash and I'm also using the 9 LED tower lights for the clock. Of course its all NON correct but you can see your dash at night!!
      • William K.
        • April 1, 1990
        • 37
        Thanks for the responses, and the photo's, went to the web sight many options. White bright light looks good. In your photo do you have the rheostat on the highest setting? Anyone else use different LED's
