odd 64 fuel injection set up - NCRS Discussion Boards
  • Matt L.
    • February 23, 2010
    • 337
    i have never seen something like this. is this rare or some race piece?
    take care,
    matt
    • 43212
    Re: odd 64 fuel injection set up
    take care,
    matt
    matt------
    I can tell you this much: it was never, ever used in PRODUCTION on any Corvette, 1964 or otherwise.
    • Matt L.
      • February 23, 2010
      • 337
      matt------
      i agree 100% Joe. i was just curious if this was a rare racing piece or ?
        • 43212
        Matt------
        That I don't know. Some of the early FI afficionados, especially someone like Ken Kayser, would probably know.
        • Tim S.
          • May 31, 1990
          • 704
          I remember John Eyestone having a dual meter F.I. unit. Legend has it it was a racing unit.
          Tim
          • Bruce B.
            • May 31, 1996
            • 2930
            Matt,
            Bill Thomas of Cheetah fame modified some pre 63 units with dual air horns but I have never seen a 63-65 unit done in this manner.
            It would look so cool on my 65...
            Bruce B
            • Bruce B.
              • May 31, 1996
              • 2930
              Here are a few pictures of modified 2 air horn Rochester units:
              Tom Parsons and Jim Lockwood,s names were mentioned as being knowlegable of these types of modifications .
              • Steven B.
                • June 30, 1982
                • 3985
                I have seen a couple of the top mounted horns on Bill Thomas units and one side mounted like this one. I have some pics somewhere on Cheetah and '63 Corvette (a white GS before body mods IIRC).
                • Jim L.
                  • September 30, 1979
                  • 1808
                  take care,
                  matt
                  As others have indicated, this FI unit has been modified to accommodate dual air meters. In all probability, the original reason would have been for racing purposes. In any event, to make dual air meters operate properly also requires modifications to spill valve in the fuel meter. It's not as simple as bolting on the 2nd air meter and going for a spin.
                  I'm not aware of any units that left RP with dual air meters, but I'd never say it never happened.
                  It would have been nice if the listing had included more pictures. The asking price is pretty steep with no more information than was included.
                  Jim
                    • 43212
                    Jim
                    Jim------
                    Yes, usually the folks willing to spend BIG $$$$ are those looking for factory-original parts, not modified/experimental pieces. Of course, if this were a unit that was originally used on some famous race car, that would be a different story (assuming a potential buyer actually owned that car).
                    • Bruce B.
                      • May 31, 1996
                      • 2930
                      I find it strange that the unit has a choke on the front air meter.
                      Typically not seen on race setups, I believe.
                      • John D.
                        • December 1, 1979
                        • 5507
                        Personally not my cup of tea although i worked on a Gulf Research unit a few times. All we did is try and figure out the linkage abortion so the unit could be on display at the NCRS national at Seven Springs in the old days.
                        Guys do not realize the importance of the forward balance tubes. On some of those units if the tube is not squeaky tight it affects the cars idle and performance.
                        Bruce, I agree with you on the choke. It has a choke housing but it doesn't have any other choke parts. No fast idle cam, no choke rod, etc. So what the choke housing is doing is questionable. Maybe it's there just to open the choke butterfly.
                        Meanwhile I was never interested in dual air meter units although they were offered to me over the years. Hard enough to get a stock unit running dead nuts for PV.
                        Grady Davis was not that successful on those Gulf Research units according to their mechanic Joe Dzorchak (sp)
                        He said it was basicially just an experiment and having some fun. Joe also worked for Don Yenko and was was Don's best FI guy in the old days. He's gone now.
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          here is some more info on the gulf dual air meter FI. http://www.racingicons.com/gs/004/gulf.htm
                          • Jerry G.
                            • April 1, 1985
                            • 1022
                            I looked at the testing data and see that the right side was running leaner than the left. On my road race FI unit this has been a constant problem. It seems to be amplified by higher flow rates. I don't really have a good or even plausible reason why this is so but this test data seems to confirm what I see. Jerry
                            • Clem Z.
                              • January 1, 2006
                              • 9427
                              http://www.micro-controls.com/fiparts-63spiders.html would changing the length of the tubing on one side change that ??? looks to me that all the tubing is the same length and that must be for a reason
