Correct C2 Exhaust Clamp Vendor - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2669
    Can someone tell me where I can purchase the correct mid pipe and muffler tip clamps the have the reinforcing rib as shown in Michael Hanson's picture?
    James West
  • David L.
    • July 31, 1980
    • 3310
    Re: Correct C2 Exhaust Clamp Vendor
    James,
    I have some 2" and 2 1/2" NOS aftermarket guillotine clamps that are very similar with the rib. Finding NOS GM clamps might be a bit more difficult.
    Dave
    • Keith B.
      • December 1, 1991
      • 397
      Where were these purchased and are they still available? I am interested in obtaining a set of 2 and 2.5 inch
      Keith Burmeister
      • David L.
        • July 31, 1980
        • 3310
        Keith,
        I purchased all my guillotine clamps back in the 1980's at swap meets. I doubt that they are still available.
        The blue/white box (2") does not have a manufacturer, just "C200", "8602", "LEAK-TITE CLAMP", AND ""10-01276-5" on the flap.
        The green/white box (2 1/2") has "Versatube Corp., Troy Michigan 48084" as the manufacturer and described as "EXTRA HEAVY DUTY", "New ROL-TITE", and "Reinforced 12 Gauge Steel Saddle with Reinforced Rib".
        Dave
        • Robert K.
          • July 31, 1984
          • 213
          Close!
          • James W.
            • December 1, 1990
            • 2669
            Originally posted by Robert Keese (7713)
            Grainger does not sell a true 2-1/2" outside diameter clamp, only the 2" per a phone call to the Omaha, NE. store on 11/2/12. I ordered a pair of the 2" to see how they look.
            James West
            • Jeff C.
              • 40
              James - did you check out the 2.5 inch Long Island Corvette clamp? Next best thing? Jeff Cornwell
              • Gary B.
                • February 1, 1997
                • 7054
                Jeff,
                By any chance do you have an image of the 2.5" clamp from LIC that you could post?
                Gary
                • Peter L.
                  • May 31, 1983
                  • 1930
                  Gary - They probably have a picture in their catalog on-line. Pete
                  • Gene M.
                    • April 1, 1985
                    • 4232
                    The Granger clamp is not correct. The "U" bolt s/b a 5/16" thread. The listing says it is 3/8".
                    • Gary B.
                      • February 1, 1997
                      • 7054
                      Do anyone know if any of the repro 2.5" clamps have a 5/16" thread?
                      Gary
                      • Alan D.
                        • January 1, 2005
                        • 2049
                        The 2.0 center clamp at LI is not correct, so would suspect the 2.5 is not correct. The center clamps (at least for 64) did not use a nut and L washer setup like the rear 2.0 clamp did.
                        The production units (center clamp) consisted of Bolt-U (3853724), a Clamp (3791357), and Nut (273802) While the service replacement part (3754883) was the entire assembly and used for both the center and rear. I would guess that the production parts did not have a part number on them. Now my 64AIM does not have the N11 section listed so exactly what part numbers were used I would like to know, please.
                        The LI rear clamp looks pretty good, no part number and has the nut and L washer, view LI # 33-41
                        • Jeff C.
                          • 40
                          Gary - here's a picture of the LI corvette 2" clamp. Has the 5/16 studs and uses a nut and lock washer. The 2.5 inch looks the same, but does not have the raises area in the middle bottom. And uses a nut and lock washer. Looks like 3/8 inch studs and takes a 9/16 nut. I don't have a picture off the car. I saw a set of old NOS GM 2.5 inch on ebay and chased them for a while, until the got over $400!! I have a set of GM rear 2 inch on my car - will see if I can find a picture. I got them from a FL corvette parts dealer some years back. Jeff
                          • Jeff C.
                            • 40
                            I forgot I copied down a picture from the ebay auction of the 2.5 inch NOS GM clamps - here they are. One side of the clamp has a large C and then below it Pat No 2719345 and then 2 1/2. I tried to take a picture of the GM 2 inch clamps on my 67 - tough to get at. The raised portioin at the bottom has stamped in it GM 3754883 and the other side has a 2 with a circle stamped around the number. Hope this helps! Jeff
                            • Scott S.
                              • September 11, 2009
                              • 1961
