1966 425 Heads picture - NCRS Discussion Boards
  • Anthony S.
    • April 30, 1998
    • 156
    Could someone post pictures of the front of correct heads (both drivers and pass side) for a 1966 425 HP car? Thanks in advance.T
    (a search of the discussion board did not yield anything)
    • 43221
    Re: 1966 425 Heads picture
    Anthony------
    Here is an example:
    • Anthony S.
      • April 30, 1998
      • 156
      Thanks Joe. What date do these have?
      • William C.
        • May 31, 1975
        • 6037
        The most unique feature of these heads is the provision for the sparkplug heat shield retain bolt on a small boss nest to the exhaust port. That is pretty much what makes then detectible from later heads at 10 foot distances.
        Bill Clupper #618
        • Bob J.
          • December 1, 1977
          • 714
          I thought some/all had a T casting symbol on the end of the head.......plus the spark plug barrel holes that Bill mentioned.
          • Anthony S.
            • April 30, 1998
            • 156
            Or triangles markings at the front with a G Inside?
            • Kenneth B.
              • August 31, 1984
              • 2089
              If the part # is correct & date code is also it right.
                • 43221
                Anthony-----
                May 26, 1966
                • Anthony S.
                  • April 30, 1998
                  • 156
                  I believe that there are other heads that also have the heat sheld characteristic. So are there any
                  Other identifiers to look for? On the front part of the head?
                  • Anthony S.
                    • April 30, 1998
                    • 156
                    StIll looking for more pictures. Heads as installed on a car that passes judge's eyes. Thanks....
                      Tony -
                      Here's a '66 L-72.
                      • Anthony S.
                        • April 30, 1998
                        • 156
                        John thanks for posting. This is a good view of the heat shields. But I am very interested in a close up Of the front ofthe head showing thoses details. Thanks tony
