62 radiator? - NCRS Discussion Boards
62 radiator?
  • Roger B.
    • June 30, 1991
    • 82
    62 radiator?
    Pls advise if I have the correct radiator in my 62 built april 16.
    top outlet reads 3150896 center of top reads H 18 6
    bottom outlet reads 3150897.
    Thanks for any help
    Roger
  • John F.
    • March 23, 2008
    • 2406
    Re: 62 radiator?
    I think H 18 6 is August 18, 1966.
    • Terry B.
      • December 6, 2010
      • 73
      Re: 62 radiator?
      If you radiator has a foil label on the right side (black lettering with Harrison in blue) it should also have a part number and date code stamped directly into the top of the radiator just to the left of the center (these may be covered by a paper servicing instruction and warning label with green lettering). The part number should be 3150916 and the date code should be somthing like C62 (March 1962). On my radiator the label had to be removed to read the stampings.
      On the top hose attachement (left side) I find stampings of 3150896 and D6 22. The bottom hose attachment has a stamping of 3150897.
