Removing old masking tape? - NCRS Discussion Boards
  • Bruce B.
    • May 31, 1996
    • 2930
    With my latest project I received lots of parts that were wrapped with newspaper and held together with masking tape.
    How can I get the tape off metal (valve covers +++} and plated and painted surfaces?
    Bruce B
  • Dick W.
    • 10483
    Re: Removing old masking tape?
    Goop, Go-Jo, WD-40 etc and a lot of patience. Nothing worse than cheap tape, heat, and age
    Dick Whittington
    • Russ S.
      • April 30, 1982
      • 2163
      Also 3M adhesive remover. If more than just the glue is left from the tape, you will need to let it soak a bit and may need do it a second time.
      • John F.
        • March 23, 2008
        • 2415
        Cooking oil.
        • Jim T.
          • March 1, 1993
          • 5351
          Bruce B
          WD-40 might do the trick.
          • Bill H.
            • August 8, 2011
            • 439
            WD40 takes a while and numerous applications.
            Lately I've been using Goo-Gone Citrus (Walmart), it's really nice, even cut the white puddy that holds the plastic vapor on to the C2 doors.
            What's great about it is it's citrus-water based, washes off with water, doesn't hurt paint at all and dosen't discolor aluminum.
            • Gerry P.
              • October 28, 2007
              • 144
              I've found that old fashioned lighter fluid works well to soften and remove many adhesive residues.
              • Peter M.
                • April 8, 2007
                • 570
                3M Adhesive Remover will do the trick without harming your parts. Its the same stuff as Goop which Dick recommended.
                  It also comes in a 1-quart can with a plastic nozzle as #08984 if you prefer a liquid.
