3820929 shock mount - NCRS Discussion Boards
3820929 shock mount
  • Timothy B.
    • April 30, 1983
    • 5186
    3820929 shock mount
    I have the outer strut/shock mounts off my 67 and found the 929 (drivers side)mount has been replaced by the #265 HD suspension mount. The other side is the correct 3820930 mount and I want to replace the drivers side to be correct so if anyone has a 3820929 mount that's in nice condition please contact me private as I want to get my car back together.Thanks, Tim
  • David L.
    • July 31, 1980
    • 3310
    Re: 3820929 shock mount
    Tim,
    I have a pair of used 3820929/3920930 shock mounts that I bought is a box of misc. Corvette suspension parts at Carlisle many years ago. Unfortunately I did not notice that the 2 mounts were hack-sawed off at the end with the cotter pin hole so they are junk. One is forged "3820929" & "2DC" and the other is forged "3820930", "GP6" and a large "2".
    I also have a NOS set of 3829265/3829266 mounts. One of them is forged "3829265-66", "1", and "E". The other one is forged "3829265-66", "3", and "E".
    There is currently an NOS "3820930 RH" mount on Ebay (not mine) if you don't mind coughing up $100 plus shipping.
    The next time I crawl under my 1966 I will check the exact forging numbers on the shock mounts.
    Dave
      • 43219
      Tim-----
      The likely reason that you have the HD mount is that the HD mount replaced the original 3820929 mount for SERVICE in February, 1978. So, after that time if a shock mount shaft had been replaced, GM would have supplied the HD mount.
      Many of these mounts were damaged by corrosion and/or during removal. Inspect yours for corrosion damage which often results in serious pitting of the shafts. Pitting seriously weakens the shafts and makes them prone to breakage.
      • Scott S.
        • September 11, 2009
        • 1961
        Tim-----
        Joe,
        If you have one HD service replacement and one original, is there any reason this would cause a problem from a functional standpoint? Isn't the angle different on the HD shock mount, to allow more clearance for the HD shock absorbers?
          • 43219
          Originally posted by Scott Smith (50839)
          Joe,
          Scott-----
          The configuration of the 2 mounts is slightly different as you describe. However, using a HD mount on one side and a standard mount on the other will cause no functional problems, at all.
          • David L.
            • July 31, 1980
            • 3310
            Joe,
            You are correct. Corrosion is probably the reason why the 3820929/3920930 shock mounts (as shown in the photos below) were hack sawed off.
            Dave
            • Timothy B.
              • April 30, 1983
              • 5186
              Thanks everyone, if I can't locate a nice used part I will install the HD mount and wait until Carlisle to pick one up. It's not a big deal to change out later.
              • Wayne M.
                • March 1, 1980
                • 6414
                Here's the pair off one of my '65s.
                r
