67 windshield washer bag location with A/C - NCRS Discussion Boards
  • Domenic T.
    • January 29, 2010
    • 2452
    I installed factory A/C in my 67 coupe in the 70's and didn't have the windshield washer bag mounted.
    I am doing a frame up and want things where they are supposed to be and have already finished the battery acsess panel and am wondering where the bracket mounts?
    DOM
  • Peter L.
    • May 31, 1983
    • 1930
    Re: 67 windshield washer bag location with A/C
    Dom - Check the 67 Corvette AIM, UPC C60, SHEET B3. It looks like that has the dimensions and the bracket is used as the template. If you need any other dimensions, let me know and I'll make any specific measurements you want/need. Pete
    • Kenneth B.
      • August 31, 1984
      • 2091
      The hole closest to the motor is 2" down &1/4" in from the bottom of the drip rail on mine. The bracket hangs over the edge of the inner fender a bit.
      KEN
      • Domenic T.
        • January 29, 2010
        • 2452
        Thanks Guys,
        Wayne & Pete Thanks, I am going to the shop and will look for that in the 63 AIM.
        Ken, thanks for telling me where the bracket was located that helps.
        Don't know how I got 2 posts the same with 1 entry???
        DOM
