Any advice before I start to change out the incorrect tube with the correct tube? The motor is in the car. I envision the following steps:
remove the top ignition shielding
remove the rear bolt that connects the ignition shield top to the vertical shielding
remove the clamp from the starter bolt
remove the bolt out of the top of the road draft tube
slide the rubber spark plug wire holder out of the road draft tube slot
slide the old tube down the side of the block and off
make sure the spark plug wire holder on the correct tube is bent the same angle as the incorrect tube
slide the correct tube up the side of the block into place
reverse the other steps
