torque question - NCRS Discussion Boards
torque question
  • Wayne P.
    • January 22, 2008
    • 444
    torque question
    Would anyone have the torque numbers for the rear axel shaft bolt cap torque . also the main drive shaft clamps. ( Threaded axel )
    thanks
    • January 31, 1988
    • 43193
    Re: torque question
    thanks
    Wayne-----
    If you're referring to the bolts which retain the caps to the stub axles, the torque is 45 lb/ft.
    I don't know what you mean by "main drive shaft clamps".
    • Wayne P.
      • January 22, 2008
      • 444
      Re: torque question
      I ment the drive shaft clamps to yokes . thanks
        • November 30, 1997
        Re: torque question
        Wayne -
        The '64 A.I.M. shows 60-90 ft-lbs. for the outer half-shaft U-joint flange-to-spindle flange bolts, and 12-15 ft-lbs. for the driveshaft U-bolt nuts.
          • January 31, 1988
          • 43193
          Re: torque question
          Wayne------
          All 1953-67 Corvettes used u-bolts for driveshaft u-bolt retention. None used straps with bolts. However, 1968-70 with automatic transmission as well as most 71-82 did use straps with bolts. The torque for these bolts is 15 lb/ft.
          • Wayne P.
            • January 22, 2008
            • 444
            Re: torque question
            Thanks guys sorry for the incorrect verbiage . John thanks for the info that is what I required. Is their a trick or a special socket when installing the French locks . I ground down a socket still difficult.
              • November 30, 1997
              Re: torque question
              Wayne -
              I haven't found anything special required - put a bit of oil on the bottom of the bolt heads, assemble the french lock to a bolt pair, install the pair finger-tight, then install the other pair the same way and torque all four bolts, then bend one tang at each end of the french lock against a flat on the bolt head. The oil on the bottom of the bolt heads minimizes the possibility of twisting the french lock as you approach correct torque.
              • Timothy B.
                • April 30, 1983
                • 5177
                Re: torque question
                Wayne,
                Just to add to what John said, neverseize may work also.
