2005 corvette wont come out of park...sometimes - NCRS Discussion Boards
  • Mike G.
    • July 31, 2002
    • 709
    2005 corvette sometimes wont come out of park. when you hit the brake pedal most of the time you hear the click and it works fine. sometimes you dont and you are stuck. what do i need?
  • John D.
    • June 30, 1991
    • 875
    Re: 2005 corvette wont come out of park...sometimes
    mike
    Here's some info from the service manual:
    Automatic Transmission Shift Lock Control Description and Operation
    The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
    The automatic transmission shift lock control solenoid
    The remote control door lock receiver (RCDLR)
    The transmission control module (TCM)
    With the ignition in the ON position, battery positive voltage is supplied to the automatic transmission shift lock control solenoid located within the shift lever assembly. The automatic transmission shift lock control solenoid receives a ground from the RCDLR. The RCDLR receives input thought data communications from the TCM indicating transmission gear position and brake pedal position. With the shift lever in the PARK position the internal park switch of the shift lever assembly closes allowing current to flow to the RCDLR. When the RCDLR receives a data communication that the brake pedal is depressed and the transmission is in the PARK position the RCDLR supplies a ground the shift lock control solenoid control circuit. This energizes the solenoid and allows the shift lever to be moved out of the PARK position. With the shift lever out of the PARK position the internal park switch in the shift lever assemble opens, this de-energies the shift lock control solenoid.
    If it's intermittent it could be a bad connection. otherwise the culprits are either the brake switch, transmission floor shift control in the console, or the remote control door lock receiver (RCDLR). If the brake lights work fine when it happens it's most likely not the brake switch....
    • Mike G.
      • July 31, 2002
      • 709
      thanks. i will print this and try again.
