How do you protect blue certification label to repaint? - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    How do you protect it when you shoot the jambs?
    Bill
    • 6942
    Re: How do you protect blue certification label to repaint?
    Bill when I painted my 72 I took a little extra time masking of the labels and painted the jams. I will say that becareful removing the tape its best to find a good edge that the sticker is adhered, there is a clear sheild over the sticker in 72. I did start to peel the clear so I started at another cornor. Once these stickers are removed they will not go back on car.take the extra time needed to do it right.
    • Bill W.
      • March 1, 1980
      • 2000
      If that jamb is the correct color dont paint it or just paint the bad areas. If its lacquer it will blend .
      • Bill L.
        • February 1, 2004
        • 1403
        I wish it still was the original paint. It was originally Nevada Silver. It was repainted gray metallic.
        • Jake D.
          • August 31, 1984
          • 134
          This might be the place to contact for your door sticker.
          • Kenneth B.
            • August 31, 1984
            • 2088
            [QUOTE=Bill Lennox (41387);598541]How do you protect it when you shoot the jambs?
            I would think you could coat it with anything like Vasoline & the paint would not stick. As long as it does not affect the sticker I think the paint should rub off. I have not tried it on the door sticker though.
            KEN
            • Bill L.
              • February 1, 2004
              • 1403
              Ken,
              You just gave me an excellent idea that should work.
              When a good body shop paints a car they spray a soap like substance that dries on the car to prevent overspray on the remainder of the car.. It washes off like soap.
              Bill
              • Lawrence M.
                • February 1, 1995
                • 404
                Originally posted by Jake Dykstra (7835)
                http://www.ecsvin.com/index.php
                Some of the repops do not have the correct shade of blue which usually will result in a deduction. Save the original if at all possible.
                Larry
                2002 Z51 Convertible
                1969 L46 Convertible
                • Reba W.
                  • 937
                  And some also do not use the correct type font.
