1961 T10 Transmission Identification - NCRS Discussion Boards
    • June 21, 2010
    • 17
    I have a 1961 Corvette (car built in March 1961) with a T10 4 speed transmission that I am trying to identify. The main housing (cast iron) has "T10 IB WG Div" cast into the right side. Below that is cast "G.26.62" which I believe is the casting date? On the left side is samped "WJ62-2", which I believe is the assembly date stamp? The rear housing numbers and dates make sense, T10 7B WG Div, 7-20-60. From what I've read the T10 1B was used for 1960 and early 1961 only, late 1961 and 1962 used the T10 1C. My question is, how does a T10-1B (Cast Iron) housing have 1962 casting and stamping dates on it, or am I missing something?
  • Mike E.
    • February 28, 1975
    • 5141
    Re: 1961 T10 Transmission Identification
    Best bet is one of two things: either a put together unit from somewhere along the line, or even more likely, you original needed repair, the case was worn, and different case was used.
      • 43258
      John-----
      The main case was cast on July 26, 1962 and the transmission it was originally part of was assembled on October 6, 1962.
      How could a T-10-1B have been assembled in 1962? Well, it could have been a SERVICE transmission and that SERVICE transmission contributed a main case which was used to replace the original one used for your car.
        • June 21, 2010
        • 17
        Thanks for the help, the numbers confused me being on a T10 transmission, I didn't think it could be something other than a Corvette transmission.
          • 43258
          John-----
          The Borg Warner T-10 was not only used on GM cars, it was also widely used on Chrysler and Ford products.
            A T10-knowledgeable poster on another forum indicated that the T10-1B main case was also used in later years in Studebakers and some AMC products - that's probably where the 1962-dated T10-1B case came from.
