69 fan to clutch bolts - NCRS Discussion Boards
  • Stanley S.
    • December 14, 2007
    • 57
    Does anyone know what the correct headmark, length, and finish should be for the bolts to attach the fan to my SC clutch. Thanks. Stan
  • Edward J.
    • September 15, 2008
    • 6950
    Re: 69 fan to clutch bolts
    Stan, I believe that the fan clutch had studs on them.
    • Stanley S.
      • December 14, 2007
      • 57
      Edward,
      The SC clutch I just bought on e-bay dated 7-16-69 has no studs, only threads to accept a bolt. I've seen pictures of other mid to late 69 clutches the same way. Have the studs been removed? Thanks.
      Stan
      • Edward J.
        • 6950
        Stan, maybe someone else will chime in, I cannot be 100% sure as I know that most of the fan clutchs I have seen have studs. I know some of the later years did go to bolts to retainer fan to clutch. And my 72 sm. block has studs.
        • Bill L.
          • February 1, 2004
          • 1403
          My 70 has an "A" headmark with three lines for Grade 5 bolt.
          1/2" head fine thread with an overall length of 3/4" including the head. Threads are 1/2" long.
          Hope that helps.
          Bill
          • Stanley S.
            • December 14, 2007
            • 57
            Bill,
            Thanks. Do you know how they are plated?
            Stan
            • Bill L.
              • February 1, 2004
              • 1403
              Looks to me like they were gray/black phosphate.
              Bill
              • Bill C.
                • May 31, 1989
                • 424
                Hope that helps.
                Bill
                The "A" headmark is what I see, phospated, 1/2" long
                  • 43248
                  Originally posted by Stanley Schield (48300)
                  Edward,
                  Stan
                  Stan------
                  It depends which 1969 clutch you're talking about-----some used studs for fan attachment and some used bolts.
                  • Jeffrey S.
                    • May 31, 1988
                    • 1890
                    Early '69 used bolts. My Oct. '68 came with bolts. I will check later for headmarkings.
                    Jeff
                    • Stanley S.
                      • December 14, 2007
                      • 57
                      Stan------
                      Joe,
                      The clutch is a 7.25" diameter with a rectangular bimetallic strip on the front and with straight fins. It is stamped SC by the date on the flange that bolts to water pump pulleys. I was thinking this would be the correct clutch for my 69 L71 built in Oct 69.
                      Stan
                      • Chris H.
                        • April 1, 2000
                        • 837
                        Stanley, here's a photo from my Dec 10, 68 car.
                          • 43248
                          Joe,
                          Stan
                          Stan-----
                          Does the front of the clutch have a "dish-like" perimeter around the ribbed center section?
                          • Stanley S.
                            • December 14, 2007
                            • 57
                            Stan-----
                            Joe,
                            Yes, the front has an area outside the fins that looks similar to a pie pan that extends past the fins about 1.25". I can try to post a picture tomarrow.
                              • 43248
                              Joe,
                              Stan------
                              The fan clutch is a GM #3937771 which was used on many 1968-69 big blocks. It used BOLTS to attached the fan to the clutch. Other 1969 fan clutches used on most small blocks as well as some big blocks used STUDS to attach the fan to the clutch.
