Master Cylinder Rebuild - Brass Sleeved - NCRS Discussion Boards
  • Jimmy G.
    • November 1, 1979
    • 977
    I have a 1960 that needs a MC rebuild (leaking). It has already had a brass insert installed. Anyone have any luck honing these brass inserts and installing a kit. Any does or donts. The sleeve appears worn so I hope a quick honing and a fresh kit will solve my brake problems. It is hard enough to stop a 1960 at 100 MPH ----- without brakes even more difficult!!!!!!
  • Norris W.
    • December 1, 1982
    • 684
    Re: Master Cylinder Rebuild - Brass Sleeved
    I've been curious about this also. I've sent several to Virginia in recent years and they install the brass sleeves, but I've always wondered why they don't use stainless. I don't remember the explanation when I asked the question several years ago, but it didn't seem logical at the time.
    • Larry M.
      • January 1, 1992
      • 2701
      Brass is less costly, more mallable, and easier to work with. But stainless steel should/will last longer in most circumstances.
      Larry
      • Dick W.
        • 10483
        Billy always used brass and told me it machined so easy. I assume White Post still uses brass, I will find out shortly as I am sending them four unobtanium wheel cylinders and a master cylinder.
        Dick Whittington
          • 43247
          Jimmy-----
          I greatly doubt that you'll be able to hone the master cylinder, install a kit, and get it to work properly. My experience has been that honed master cylinders, even slightly honed, just do not work well.
          You MAY be able to get someone to re-sleeve it. However, I think that product liability requirements may make it difficult (that's why most master cylinder/caliper rebuilders will not accept previously sleeved units as cores).
          The thing I'm surprised about is why the master cylinder sleeve you have is showing signs of wear. A brass sleeve ought to last about as long as anyone currently on earth is going to need it.
          • Dick W.
            • 10483
            Jimmy, is it worn, or just polished where the cup slides? If you want to resleeve it, there is a shop here that has been doing them for over 30 years. They don't have any kits, etc, just do the machine work.
            Dick Whittington
            • Guy M.
              • November 1, 1993
              • 500
              Where would one send a MC for sleeving, my 54 could probably use it as I only honed it.
              • Ronald W.
                • July 31, 1993
                • 23
                To remove brass sleeve simply heat in oven at 500 degrees for half hour. This will melt the loctite adhesive and the sleeve will fall out. I had mine resleeved in stainless steel by adams.
                • John F.
                  • March 23, 2008
                  • 2415
                  My local machine shop put a stainless sleeve in mine. No problems.
                  • Dick W.
                    • 10483
                    Lonestar Caliper, CSSB, Apple Hydraulics, White Post Restorations, plus there are several more that have been mentioned in the past. I have used a local machine shop when all I needed was a sleeve, White Post for several antique cars, CSSB and Lonestar for some Corvette stuff. All do good work
                    Dick Whittington
                    • Peter M.
                      • April 8, 2007
                      • 570
                      Jimmy:
                      Erich Cornely (46879) posted this rebuild tip just last week:
                      P.
                      If there is any pitting in the bore just rebuilding it might not last too long or it might leak from the get go. Another option would be to have it sleeved and rebuilt. That way you retain the original master cylinder and have a new wear surface ( bore ). Here is an example of some places that provide that service:
                      Antique and custom hydraulic brake and clutch cylinder restoration specialist
                      http://www.resleeve.com/sleeving.htm.
