wiper motor and heater fan - NCRS Discussion Boards
  • Matt L.
    • February 23, 2010
    • 337
    i need some help figuring this out on my '64. my wiper motor and heater fan both stopped working at the same time. fuses are good. wires look good and all connections are there. i do hear the wiper motor trying to start. it clicks like a starter solenoid. the wiper arms and assembly are not stuck or frozen in place. is this a coincedence that both stopped working?
    thanks in advance for any help or advice.
    take care,
    matt
    • 6950
    Re: wiper motor and heater fan
    take care,
    matt
    Matt, take a test light out to the blower motor connection and see if it lights when you turn fan on. it should get brighter with the increase of each speed, ( If you own a volt meter that would be better). As for the wiper motor it sounds like you maybe powered up , But take the test light a probe the connector wires one at a time and see if there is power. when turning switch. I dont have a 64 manuel in front of me so I dont know the wire color for the power side. make sure to look at the ground wires, the blower motor has a black wire with a spad attached to the motor itself.
    • Donald H.
      • November 2, 2009
      • 2586
      If they stopped working at the same time, sounds like a ground wire problem if the wiring is the same as my 66. The ground for the blower and wiper are connected. The test I have done is turn the blower switch on then jumper from the ground (black) terminal on the blower motor under the hood directly to the battery negative terminal or another good ground. If it runs then you have a ground problem.
      If it is the ground wire, on my 66, that Small harness runs from a ground connection on the starter to the blower motor, then on to the wiper motor
      Don
      Don Harris
      Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
        Don
        Matt -
        The top end of that ground pigtail (which is taped inside the starter leg of the engine harness) is as Don noted above; the bottom end has a large ring terminal, which goes under the head of the outboard starter-to-block attaching bolt. That's the sole ground for both the heater blower motor and the wiper motor.
        • Matt L.
          • February 23, 2010
          • 337
          thanks guys! i'm gonna look into it further now. i appreciate the help. i'll let you all know if it's fixed.
          take care,
          matt
          p.s. john , i am looking forward to meeting you at the judging school coming up the 1st weekend in november. i just hope my brain can absorb all your knowledge and knowhow.
          • Matt L.
            • February 23, 2010
            • 337
            found it guys! the connector ground on the starter bolt was broke off. i grounded it again and everything worked again. thank you guys again. i really appreciate being pointed in the right direction.
            take care,
            matt
