"Red" Antifreeze ? - NCRS Discussion Boards
"Red" Antifreeze ?
    • 15616
    Re: "Red" Antifreeze ?
    My NAPA has it on the shelf.
    • Dick W.
      • 10483
      NAPA, Carquest, Autozone, O'Reiley's, and Advance all have it in stock here. Plus Wallyword
      Dick Whittington
      • Ronald L.
        • October 18, 2009
        • 3248
        #18
        Larry has a copper rad and a big block furnace under the hood and he lives in nearly the warmest part of the country.
        I really think he needs a DeWitts as you can't see the difference, they have the original tools for this and then the rest of this is just those motors kick out lots of BTU's.
        Up here in the cold north fall is a fun time to get these BB's out as you never have to worry about being cold, nor the car shooting much past 210. Put the top duwn, the windows up and pull that heater switch and enjoy.
        Larry there is a surface tension modifier that causes the water in the coolant system to adhere better to the metal and theoretically transfer more heat.
        I don't know if they work nor am I all that anxious to experiment with my cooling system.
        I hope some of you are listening when I tell you that I had the job back in 80-ish to fix some of these issues with incompatible coolants, sloppy work practices, and arriving at standards for the suppliers. I went all over the country to these suppliers and all the plants.
        They were a real mess as what worked for cast iron engines and copper was one thing, cast iron and aluminum another, and then there were those early aluminum blocks, another thing yet.
        I did all the formula testing, can't say what is in any given brand on the market as their formulas were/are trade secrets - all I can say is don't go experimenting, and for our vintage cars, change the stuff every year. I know some will cry, but the protective chemicals in these are like anti-oxidant vitamins and they get used up quickly if you have old stuff in your coolant system, like an original block or original soldered copper core. Once you get the corrosion started...ciao.
          • 15706
          #19
          Originally posted by Russ Steinhaus (5540)
          The auto parts store is telling me that Dexcool (orange) is the same thing as G05. Is this incorrect? Auto parts store doesn't even have an antifreeze that says G05 on it.
          No - different corrosion inhibitor technologies. Dexcool is OAT, G-05 is HOAT.
          Dexcool is patented and trademarked, and anything that meets the Dexcool spec will say Decool on the label.
          • Bill B.
            • December 1, 1993
            • 192
            #20
            Bill
            1961 Black/Silver/Red Int. 283/315 FI power windows. Frame off 65% completed.
            1989 White/hard top/Grey Int. daily driver 167,000 miles
            "The problem with Liberalism is that eventually you run out of other people's money" Margaret Thatcher
            • Dick W.
              • 10483
              #21
              Originally posted by Bill Berger (23665)
              Bill
              Bill, I think that you will probably need a very LARGE miracle
              Dick Whittington
