Starter for '69 427/435 - NCRS Discussion Boards
  • Jack O.
    • July 31, 1996
    • 525
    Looking for a starter for my '69 427/435 and see that they sometimes come in aluminum vs. cast iron nose. Which is correct for my '69(manufactured in Nov '68)?
    Jack
    Jack Ottofaro
  • Jack O.
    • July 31, 1996
    • 525
    Re: Starter for '69 427/435
    One other thing, does my engine require a high torque starter, i.e. should I be looking to get something other than a standard rebuilt starter? Any suggestions?
    Jack Ottofaro
    • Dick W.
      • 10483
      A 435 definitely used a high torque starter. According to the judging manual 427's used an iron nose starter with starter nose #1969309
      Your best bet to find a starter that is real and not a restamp is John Pirkle pirklesr@aol.com
      Dick Whittington
      • Kenneth T.
        • March 23, 2008
        • 631
        Jack,
        1108400, cast iron nose, high torque.
        Ken
          • 43219
          Jack
          Jack------
          Unless you're really interested in the "correct numbers" and "dates", you can easily obtain a re-manufactured starter with otherwise exact original configuration for a very modest price. You do need a 'high torque' style with a cast iron nose. The high torque style is easily identified by a 1" copper spacer located between the starter's field coil terminal and the solenoid.
          AC-Delco offers a high quality rebuilt unit under GM #1876552, aka Delco #323-254. Except for "numbers" and "dates", this starter will be virtually identical to the original. Expect to pay less than 100 bucks, including core charge, from an AC Delco dealer.
