glove box lock 62 - NCRS Discussion Boards
glove box lock 62
  • Roger B.
    • June 30, 1991
    • 82
    glove box lock 62
    How can the glove box lock be removed?
    thanks for any help
  • Anthony P.
    • June 27, 2010
    • 485
    Re: glove box lock 62
    There is a small hold that you can slide a paperclip into and it pushes on a spring loaded catch. Push in, Insert the key, turn it, and it should some out.
    • Erich C.
      • January 31, 2007
      • 137
      Here's a good old post that points out so do's and dont's:
      https://www.forums.ncrs.org/showthre...moval&uid=9927
      • Peter L.
        • May 31, 1983
        • 1930
        Roger - Are you looking to remove the glove box lock assembly from the door or are you looking to remove the glove box lock cylinder from the lock case?
        Pete
