Re: 67 L79 Oil Consumption
I have the same deal. I haven't been able to get much time into it but have pretty much narrowed it down to the rings. The compression test was very good at 185-205,the leak down on the RH bank was bad at 50-60%. The exhaust ports and intake ports didn't have any oil in them, the PVC was free and clean. I even swapped intake gaskets( mostly to test out Hylomar) but it didn't matter.
I have 4,500 miles on them so I don't think it's seating issue. The rings are Speed-pro moly top rings, reg iron 2nd ring. The federal Mogul guys pretty much said the rings will be seated by the time the cam was broken in during the first break in. I did beat on it some but that didn't work either.
I'll just have to pull the engine and go over it to see. In the meantime it runs pretty good so I'm just going to drive it until Fall!
