1969 Rear Console: Black - NCRS Discussion Boards
  • Jerry B.
    • August 31, 1994
    • 416
    GOOD MORNING, need a paint finish recomendation for restoration for this part. flat, semigloss,etc THANKS
  • Jim M.
    • February 23, 2009
    • 233
    Re: 1969 Rear Console: Black
    Would like to help Jerry, but to be honest, I'm not sure what the "rear console" is?
    • Lawrence M.
      • February 1, 1995
      • 404
      Jerry, SEM Trim Black works very well for the rear console or parking brake console as some call it. I used this to touch up some scratches and nicks and it matched almost perfectly.
      Larry
      2002 Z51 Convertible
      1969 L46 Convertible
      • Jim M.
        • February 23, 2009
        • 233
        Oh, OK, I wasn't thinking of the brake console as a "console". Would you spray that trim black on the vinyl covered console? I guess I was thinking the trim black would be used on plastic or metal parts?
        • Lawrence M.
          • February 1, 1995
          • 404
          Jim, that is a good question. I do not have the answer. I've only used the SEM Trim Black on the rear console and kick panels. There may be an answer in the archives as that is where I found out about using it for the rear console.
          Larry
          • Jerry B.
            • August 31, 1994
            • 416
            Where can I obtain SEM trim black?
            • Lawrence M.
              • February 1, 1995
              • 404
              Living near a large city (Chicago) I was able to find a small local industrial supply house that would sell to someone off the street. I had to use google search and the local phone books to find one. You may be able to find a source on line.
              Larry
              • Scott M.
                • January 1, 1996
                • 216
                You can usually find SEM Trim Black and SEM vinyl/plastic paint at automotive paint supply stores, try SEM Satin or Classic Black. Preperation is the key thing, wash with lots of hot soapy water, degreaser and prime with SEM Vinyl Prep first.
