Stamp pad - NCRS Discussion Boards
Stamp pad
  • Gene S.
    Infrequent User
    • March 1, 1978
    • 2
    Stamp pad
    Stamp pad on a 67 coupe has the following V0405HC with no other stamping on the pad - no vin derivative - car was built in april so that seems to match - any ideas.
  • Gary C.
    Administrator
    • October 1, 1982
    • 17657
    Re: Stamp pad
    Gene, moved your post from the Help Forum to the Technical Forum. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Michael W.
      • April 1, 1997
      • 4290
      Re: Stamp pad
      Does the casting number and date line up too? Got a pic?
      • Larry M.
        • January 1, 1992
        • 2688
        Re: Stamp pad
        Agree with Mike........you need to check further. HC is not a Corvette engine suffix for 1967.
        Larry
        • Tom H.
          • December 1, 1993
          • 3440
          Re: Stamp pad
          The problem I bet is going to be the casting date. I bet you will find the date to be a 68 to 69 cast engine used in a 69 model car.
          Somebody may have intentionally installed the April date block or it was just a coincidence. Either way, I'd say it's been replaced.
          Tom Hendricks
          Proud Member NCRS #23758
          NCM Founding Member # 1143
          • Paul J.
            • September 9, 2008
            • 2091
            Re: Stamp pad
            Larry
            Gene
            HC appears to be 65-67 327/250 full size Chevrolet w/ powerglide. That's from several different sources, but I can't vouch for these and you should still check it out.
            Paul
            • Ray G.
              • May 31, 1986
              • 1189
              Re: Stamp pad
              Hello Gene;
              Could it be "HO" ?
              How's that Montana winter? Almost over?
              Ray
              I hope you dance
                Re: Stamp pad
                Gene -
                As I recall, base engines in passenger cars didn't get VIN derivative stampings until 1968; what's the block casting number and casting date?
                • Gene S.
                  Infrequent User
                  • March 1, 1978
                  • 2
                  Re: Stamp pad
                  Thanks for the replies. It makes sense that it was a passenger car and thus no vin. I am sure it was replaced and whoever repaced it came as close as they could. Its still winter here and will be for a while - we will check it out further come spring - Thanks
                  • James G.
                    • May 31, 1976
                    • 1556
                    Re: Stamp pad
                    Snow level in Southern California last night was 1500 feet. 31 degrees this AM. Ski Resort Big Bear will be 8 tonight. So come on CANDY....go take a look.....
                    Sounds like a neat new project for 2011 Spring. Dee and I want to drive thru Montana next summer to or from Bloomington.......NCRS National.....or Road America 'CORVETTE WORLD TRIBUTE August 18-23. Hope to see you then Gene.
