Gentlemen, start your engines - NCRS Discussion Boards
  • David H.
    • November 11, 2009
    • 777
    Has anyone ever written up a procedure of what would be required if anyone wanted to run their engine while the body was still off the frame?
    I would like to be able to start my engine every once in a while until I am ready to drop the body back on.
    What would be required in order to do this?
    Is this a bad idea?
    It would be incouraging for me to hear it run again.
    I would love to hear the new exhaust system.
    Seems to me it wouldn't take much to make this happen.
    Any thoughts anyone?
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: Gentlemen, start your engines
    David,
    I'm told there is a past restorer article on how to build a test box for such an event. It connects the ignition and temperature gauge along with oil pressure. Other than that, you need a way to cool it and fuel it. I'd also leave the driveshaft off to keep it from inadvertantly driving away.
    I will do this before I drop my body too. In the event I need to go back into the engine, it will be an easier task.
    Maker Smoke Bobby...
    tc
    • David H.
      • November 11, 2009
      • 777
      Tracy, thanks for the help. I found the article.
      Sounds easy enough. I think I'll try it.
      • Willard M.
        • August 31, 1979
        • 422
        Also, the latest issue of "On Solid Ground" from SACC has an article of a 54 being tested this way. If you don't have access to this send me a PM with your address and I'll send you a copy. Heck, because you're in the neighborhood I may even drop it off.
        • Vinnie P.
          Editor NCRS Restorer Magazine
          • May 31, 1990
          • 1573
          Here's a video of an Adirondack tech session last weekend...Bill Meess had just finished rebuilding the motor and this was the initial start up
