New correct Holley carbs? - NCRS Discussion Boards
  • Ron H.
    • July 31, 1993
    • 96
    My 67 427/390 has an original carb that has a developed a crack in the main throttle area, and cant be repaired. I am told that someone is selling a "new", not NOS, Holley carb for this application ?
    Its a top flight car, and I am not crazy about putting an incorrect carb on.
  • Edward C.
    • March 1, 1985
    • 125
    Re: New correct Holley carbs?
    I believe Holly still make new carbs for replacements service units but they are generic and would not pass NCRS muster. Ed
    • Ara G.
      • January 31, 2008
      • 1108
      Try calling Phil Cancilla out of Jersey. He is highly respected and does great restoration work. He had an original 3811 for me that was dated and restored. It ran/runs flawlessly. I would give him a call. I personally would try to get a correct carb if I were you, but thats just personal opinion. Good luck.....Ara
      • Clem Z.
        • January 1, 2006
        • 9427
        a good welder and a good machinist can fix it. you may not like the cost but any thing made from aluminum can be repaired.
        • Joe R.
          • July 31, 1976
          • 4551
          Yes, Holley makes the exact carb for your Corvette with the part number stamped. They do not have dates as they leave it to the owner to stamp the correct date.
          You will find these carbs correct and even the slotted screws are provided if you will indicate you are an NCRS member.
          These carbs can be found on E-bay for $595.00 and the seller will pay the shipping inside the US if you again indicate you are an NCRS member.
          JR
          • Tim S.
            • May 31, 1990
            • 711
            I would contact Eric @ Vintage Muscle Car Parts. The guy has worked miracles with Holley's. His work is just awesome. Here is the link. Eric just did a carb for a friends L72. Great job at a fair price.
            Tim
            • Clem Z.
              • January 1, 2006
              • 9427
              this website has a picture of a bottom of a lifter which shows why you should polish the surface. those grinder mark should be polished out to prevent cam lobe failure.
