1972 hinge pillar weatherstrip - NCRS Discussion Boards
  • Hank H.
    • July 31, 2006
    • 76
    I have been told that late 72s went from a weatherstrip with hinge pillar attached to fiberglass piece that replace the hinge pillar section. Does anyone know the approximate date of that change? Also, was the fiberglass molded into the rear of the fender, or an additional bolt/screw on piece. Thanks
    • 11642
    Re: 1972 hinge pillar weatherstrip
    Hank,
    How late?
    Take a look at the photos via the signature below.
    This is an early June car, almost SN 23000.
    Patrick
    • Hank H.
      • July 31, 2006
      • 76
      Thanks Patrick. My January car looks exactly the same at the hinge pillar. I thought the hinge pillar part of the WS had been removed on both sides, yet there is no evidence of a screw being in the two holes. Can this be the original condition?
        • 11642
        Yes, that is probably original.
          • 6940
          Hank, The judging manuel shows that 72 did not have the extension on the piller w/strip. Unless maybe Patrick knows otherwise. I have found that to be true a few times. My apr 72 car doesn't have the w/strip ext.
          • Dave S.
            • August 31, 1992
            • 2924
            To further confuse things my late 71 (last week of 71 production) does not have that piece either. It's an original car and has never been there. All 72's should not have that piece and apparently they ran out at the end of 71 production.
              • 11642
              Correct. I can't recall when they stopped installing it, but it was before the 72 MY started.
              • Reba W.
                • 937
                I too have never seen one on 1972 and I remember one September Bowtie car that never had one.
                • Hank H.
                  • July 31, 2006
                  • 76
                  Thanks again to all!! I must have missed this in judging manual. Could not understand how original owner might have removed both pieces, or how there was no evidence of anything being installed there. Oh well, my first experience with a 72. I'm sure I have much more to learn. Reba, see you on Friday at West Jefferson.
                  • Ernie F.
                    • March 31, 1975
                    • 107
                    Now I'm going to have to check my car. Another forum member pointed this out to me. I've never paid attention to it before.
