1978 350 L82 WATER PUMP ID part number - NCRS Discussion Boards
  • Jim D.
    Infrequent User
    • December 1, 2003
    • 12
    Hello...
    I have a mid production year 1978 Corvette Pace Car with the L82.
    I was wondering about the water pump.... I need to know what numbers should be on there?.. 330818? 330813? or something else? in order to have the correct "NCRS" water pump.
    Thank You, JIM
    Re: 1978 350 L82 WATER PUMP ID part number
    The casting numbers can be tricky to read. It depends on the degree of cast iron 'fill' when the part was made. A '3' can easily look like an '8' based on this factor. Below is a close-up pix of one of these critters. Note the 'S' for Saginaw underneath the cast number...
      • 43247
      Originally posted by Jim DiPersia (41098)
      Hello...
      Thank You, JIM
      Jim------
      All late 1972 through 1982 Corvette small block waterpumps were GM casting #330813. There was no waterpump casting of GM #330818, so if you find any that look like that, what you're looking at is a 330813 that has a last "3" that looks like an "8". This is VERY common with casting numbers.
      By the way, the 330813 casting was only used for L1972-82 Corvette small blocks and L1972-1990 heavy duty trucks with small blocks.
