Hello!
So I bought a rebuilt Rochester Q-Jet carb for my 71 350/270 convertible. In the process of installing I started wondering if there was supposed to be a gasket for the Fuel inlet nut that keeps the fuel filter in place?
It sounds like there should be one, but I can't confirm. Can anyone confirm? Does anyone have a part number that I could use to find one at a local part store? Does it go inside the nut or around the base of the nut?
Also curious if there is a gasket for the fuel line itself? Maybe for the nut that screws the fuel line into the Fuel inlet nut on the carb? I couldn't find anything that mentions one for that, but I just wanted to make sure.
I just want to make sure that this fuel line to carb connection is correct and good so that I do not get any fuel leaks there.
Thanks in advance for the help!
Chad
Chad
