Breaking into a Garage in 6 seconds?
Re: Breaking into a Garage in 6 seconds?
Steve- Top
KEN65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
I just went to my garage and safety-wired the latch mechanism in the latched position. If I need to get out manually, I'll just cut the wire. Never thought of this. Thanks for the post.- Top
Suppose the Fire Department has to get in? That is what that latch is for.
Some put the cable from that latch to a keylock on the outside of the door, if the door is the only entrance to the garage.Jerry Fuccillo
1967 327/300 Convertible since 1968- Top
If the fire department wants in they will use the method they always use, ie, a chain saw. I've seen then do it many times, and they seem to love it.
If I need to open mine now that the latch is safety wired, I'll just grab a wire cutter... you won't open it with a freakin' coat hanger...- Top
No. That's not what the latch is for. The latch is to disconnect the door so you can open it in the event of a power outage. All it does is disconnect the door hardware from the electrically powered drive mechanism.
If I need to open mine now that the latch is safety wired, I'll just grab a wire cutter... you won't open it with a freakin' coat hanger...Terry- Top
Not only does my Overhead door not have windows, it doesn't have the type of lever shown in the video. Mine just has a "blade" that goes straight up and down, which would almost be impossible to pull down from the outside. It's hard for me to pull the blade down on the inside, because there's pressure on the door arm while it's closed.
No way I could imagine breaking into my garage as shown on the video.Attached FilesLast edited by Pat M.; May 26, 2010, 04:51 PM.- Top
Nope. We use a chain saw on wood doors or a rescue saw on metal doors. Noisy as hell but the complete door will be laying on the ground in about 10 seconds.- Top
You can disable the manual latch by replacing the small spring with a tight wire loop. This would also disable the ability to use the latch, a little inconvenience, but it would make it more difficult to open from the outside asin the movie.- Top
