54 parking brake flasher - NCRS Discussion Boards
  • Cathy S.
    • August 31, 2003
    • 293
    The light switch mounted on the brake handle-how do I adjust the switch. My switch operates properly off the handle but on is non op?
  • Guy M.
    • November 1, 1993
    • 500
    Re: 54 parking brake flasher
    The stud on the handle snags the switch blade when the handle is pushed all the way in. I put a small spring around mine to keep it tight closed. Bottom out the handle all the way downthen then back it off just a hair, like a 1/16th of an inch or so then position the switch tang just in front of the stud. tighten the switch down. when you push the handle in that small amount it should snag the switch blade and barely pull the blade causing the light to go out if everything else works. Hope this helps, Guy
    • Cathy S.
      • August 31, 2003
      • 293
      Thank you Guy!
      Very ingenious how you got your switch to work.
      Greg
