58 trunk latch - NCRS Discussion Boards
58 trunk latch
  • Brad H.
    • August 12, 2007
    • 724
    58 trunk latch
    What is the trick to getting the back clip on which holds the lock in place at the trunk, any special tools or small people? Thanks, Brad.
  • Mike M.
    • May 31, 1974
    • 8401
    Re: 58 trunk latch
    if the thickness of the fiberglass surrounding the lock hasn't been increased(bondo etc), the clip usually slip right over the lock cylinder if the clip is lubricated. get it started with your fingers, then if necessary, use a long bladed screw driver to drive it into its seated position. i use a thin film of vaseline on both sides of the clip( where it'll contact the fiberglass and where it seats on the lock cylinder housing. good luck,mike
    • Brad H.
      • August 12, 2007
      • 724
      Re: 58 trunk latch
      Used the trusty dremel and cutting disc to trim a little of the ear off and it slid right in. Thanks again, Brad.
