C2 (C1, C3?) tire valve caps -- Dill markings - NCRS Discussion Boards
  • Jim T.
    • March 1, 1993
    • 5351
    Re: C2 (C1, C3?) tire valve caps -- Dill markings
    Does it match the picture I posted above?
    Yes it does Patrick, and it has the indention in the nipple.
    • Peter L.
      • May 31, 1983
      • 1930
      Mike - I read your Posting as the DILL Valve Cap as one of the ones Wayne posted a picture of is the only acceptable Valve Cap for NCRS Judging. Do you have some information to share that supports that? Thanks, Pete
      • Joseph P.
        • September 7, 2009
        • 138
        #18
        Which one would be for a 62? Thank you. Joe
        • Ronald L.
          • October 18, 2009
          • 3248
          #19
          You guys just killed the flea market for the dills, maybe they'll be able to sell pickles instead
          • Mike M.
            Director Region V
            • August 31, 1994
            • 1463
            #20
            Hi Peter,
            Apparently some confusion.
            My comment was in response to Waynes question "What do Judges EXPECT to see".
            The "only" was referencing the two embosses limited to the "Dill" and the "627", meaning not to include the embossing at the 3:00 position which has not been observed on TFP Mid-Year caps.
            Would some Judges deduct for this added marking? Since they are probably just looking for the "Dill" and the "627" per the JG, perhaps not.
            HaND
            • Wayne M.
              • March 1, 1980
              • 6414
              #21
              Ron -- but look at the positive side; it's just opened up a business opportunity on eBay. Imagine, a set of five dated caps [show close-up photo of one with number/letter, which you imply is year/month]. State that the judges will be looking for this {you don't say whether NCRS, Bloomington or show-and-shine } and let the bidding begin.
              One of you tricksters should try this. Often I see topics discussed on this board that immediately result in some item being posted on eBay with authoritative description.
              • Ronald L.
                • October 18, 2009
                • 3248
                #22
                Wayne,
                Yes that is true, there are more than one seller that are also participants on this board.
                • Peter L.
                  • May 31, 1983
                  • 1930
                  #23
                  Mike - Greetings from the Land of Enchantment. Thanks for the clarification. Since I have seen the Schrader valve caps on several original mid-year spare tires (I have one) and I have no reason to believe these are not original, I didn't want to get deducted because mine didn't have a DILL 627. We're Pete
                  • Gary B.
                    • February 1, 1997
                    • 7047
                    #24
                    Schrader cap; is a photo possible?
                    Pete,
                    Any chance you could post a nice close-up image of your mid-year Schrader cap? I'd like to add such a photo to my new judging guide so that I can give full credit when judging if I see the correct non-Dill cap.
                    Gary
                    • Peter L.
                      • May 31, 1983
                      • 1930
                      #25
                      Re: C2 (C1, C3?) tire valve caps -- Schrader valve cap
                      This is the "real deal."
                      Schrader valve cap on 67 Bolt-on wheel valve stem.
                      • John F.
                        • January 1, 1979
                        • 62
                        #26
                        • Peter L.
                          • May 31, 1983
                          • 1930
                          #27
                          John - Great, we saved another original part.
                          I feel much better.
                          As Jimmy Buffet said " a pickle "DILL."" I'm sure
                          Jimmy used Schrader valve stem caps.
                          Pete
                          • Mike M.
                            Director Region V
                            • August 31, 1994
                            • 1463
                            #28
                            John
                            What is the VIN of your car with the Schraders?
                            Thank you
                            HaND
                            • John F.
                              • January 1, 1979
                              • 62
                              #29
                              Originally posted by Mike Murray (25129)
                              John
                              Thank you
                              HaND
                              1096X (mid February)
                              • Michael J.
                                • January 27, 2009
                                • 7145
                                #30
                                The '67 judging manual just says the valve stem cap is hard black plastic. Does it matter for points if it is a Dill or a Schrader?
