63 engine over spray patterns - NCRS Discussion Boards
  • Alan D.
    • January 1, 2005
    • 2049
    #31
    Re: 63 engine over spray patterns
    What do the 63 experts think of the #5 exhaust manifold stud! On the 64 it has a nut and washer (fuel filter ones) - what did 63 do?
    Are those lock washers between adapter plate and dog house used in 63? (do not over tighten)
    Should the cork gaskets show some silver on the valley side?
    Spring color?
    • Michael G.
      • November 12, 2008
      • 2158
      #32
      Thanks Michael,
      When the orange paint was sprayed on the engine at Flint, was part of the bypass hose covered by the mask that the plant used for the valve covers and manifold?
      Yeah, thanks for the heater hose evaluation: I just put that heater hose on a few minutes before the picture, I noticed the problem when I went to screw the hose clamp into the alternator bracket.
      The good news is that the engine just started and ran fine with the new valve springs. So I don't mind getting out the orange paint and masking everything, so I can paint the hose.
      Mike
      1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
      1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
      • Rob M.
        NCRS IT Developer
        • January 1, 2004
        • 12800
        #33
        Ok, first of all I believe the heads are not Tonawanda (see first attachment). Secondly I made some changes tonight as a result on the comments so far (although I couldn't do all yet)...
        * Added silver over-spray
        * Removed paint near rear PVC grommet
        * Installed gaskets intake manifolds
        * Removed paint from water pump inlet
        * Removed paint from water pump snout
        * Added throttle spring and bracket
        * Replaced black with brass 45 degrees block in PVC line
        Next add alternator, belts and pulleys!!!
        regards and thanks for all the feedback so far,
        Rob.
        Rob.
        NCRS Software Developer
        • Michael G.
          • November 12, 2008
          • 2158
          #34
          Rob.
          What are you going to do with that engine when you're done?
          Michael,
          Ok, here's the new overspray, what do you think?
          Mike
          • Michael H.
            • January 29, 2008
            • 7477
            #35
            Originally posted by Michael Garver (49693)
            Rob.
            Michael,
            Michael,
            The bypass hose looks great. That's just about how it would have looked when new. Just a bit of dull aluminum on the rear of the hose and clamp. Much of the hose orange.
            The boys at the Flint plant didn't use a shield on the hose during the paint operation like they did for big block at Tonawanda.
            I see a few items that I want to comment on but since you didn't ask about the ink stamp on the radiator, I won't mention it. Or the unpainted control arm bushings.
            • Michael G.
              • November 12, 2008
              • 2158
              #36
              OK, now you gotta tell me what you see.
              Mike
              • Michael H.
                • January 29, 2008
                • 7477
                #37
                Rob.
                Looking good Rob!
                I think the dull aluminum is close to what it would have looked like when new, although possibly just a bit excessive. This is difficult to do with a spray can.
                I would expect to see a bit of orange paint on the FI to block adapter rubber seal in the front.
                The PCV valve fitting may need to be turned slightly counter clockwise.
                The harmonic balancer retaining bolt and washer would not be painted orange. It was installed at the St Louis plant so no paint. The washer was natural, unplated. The bolt was plated zincad though.
                • Michael H.
                  • January 29, 2008
                  • 7477
                  #38
                  This may be subject to debate but I don't think 63 and 64 radiators were ink stamped "16CT" on the top. For 63-64, only a small transparent sticker with a green numeral was used. There was also a white label with green printing that may have covered, or at least partially covered the label.
                  I have LOTSA GM photos of new 63's and 64's and none have the CT ink stamp.
                  The control arm was painted with the shaft, bushings, washers and bolts already installed so all would be black.
                  I probably shouldn't comment on the alternator stator color. I don't want to start another debate.
                  • Michael G.
                    • November 12, 2008
                    • 2158
                    #39
                    Michael,
                    Thanks for explaining the "few" other "items", maybe you can tell me where to get the heater hose "straps" shown on the attached pic?
                    Mike
                    • Michael H.
                      • January 29, 2008
                      • 7477
                      #40
                      Michael,
                      Michael,
                      I think I've seen these straps in reproduction but I don't know who makes/sells them. Hopefully, someone can tell us who it is.
                      • Michael G.
                        • November 12, 2008
                        • 2158
                        #41
                        Michael,
                        I haven't been able to find them, but I'm sure some body will know.
                        I think the attached pic is and unrestored L84 radiator
                        Mike
                        • Michael H.
                          • January 29, 2008
                          • 7477
                          #42
                          Michael,
                          Hmmmm... I dunno. I don't see the part number stamped on the top. I do know that a lot of unrestored 63's have the inspection sticker instead of the 16CT ink stamp. (including one of my unrestored cars)
                          There are a ton of factory photos that clearly show the white warning label and small clear sticker.
                          The coolant warning paper sticker covers the date. Let me dig out a few factory photos.
                          That looks like a very early production car that has been restored, or at least warmed up?
                          • Michael G.
                            • November 12, 2008
                            • 2158
                            #43
                            Michael,
                            It was described to me as "unrestored", but I'm sure a few things have probably been "freshened", you have a better eye for these things than I do.
                            I'd be interested in seeing your factory photos.
                            Mike
                              Mike -
                              Doc Rebuild has them - his #2259302.
                              • Michael G.
                                • November 12, 2008
                                • 2158
                                #45
                                Thanks John, I'll get some.
                                Mike
