Upper Control Arm help - NCRS Discussion Boards
  • Wayne P.
    • January 23, 2008
    • 444
    I took the bushings out of my upper control arms and got them painted.
    They removed my tags . Not sure how to tell what is the driver side vs
    passenger side. I apologize if this is a novice question. Thanks in advance Merry Christmas
  • Pete B.
    • February 22, 2007
    • 325
    Re: Upper Control Arm help
    When you get them reassembled, it will be very obvious when you set them on the studs which one is right and which is wrong, as I remember the front has a more curved edge. Most of the things on our cars will only go on one way.
    Pete Bergmann
    2005 - 2013 C6 National Teamleader
      Wayne -
      Photo below shows the installation - angle and curvature on the front side is more pronounced.
      • Roy B.
        • February 1, 1975
        • 7044
        Wish I had the temperament to restore my 55 when I did like your's and others do. But the up keep !! And I drove my 55 right after I did restore it, we took a cross country drive 10,000 miles and still driving it today. I remember the judges hating to slid under it .
        • Wayne P.
          • January 23, 2008
          • 444
          Thanks John. That is a great help.
          • Gene M.
            • April 1, 1985
            • 4232
            Wayne,
            Just a note for when you get to the lower a arms. The sway bar mounts go toward the front as well as the two bolt holes on the shaft. You do not want to assemble the shafts on backwards. That would screw up your day.
