"correct thermostat" - NCRS Discussion Boards
  • Gary G.
    • March 1, 2001
    • 47
    I have a question regarding the correct thermostat for a 75 L48 coupe. I believe that the correct stat is rated at 195 degrees with an air pump. My car has a long disconnected air pump. Other 75's without the pump can use a 180 degree stat. In the archives, someone stated that the fan clutch was calibrated for the 195 degree stat in 75.
    Which one should I use? I have not removed the old stat, since it is currently working ok. Next flush and fill will be a good time to replace it, and I want to install the proper stat. Which brand is best and reliable?
    Thanks for any help
    • 43259
    Re: "correct thermostat"
    Thanks for any help
    Gary------
    ALL 1975 Corvettes were originally equipped with the air injection reactor system---no exceptions. Your car was originally equipped with a 195 degree thermostat. You can use either a 195 or 180 degree thermostat. I would recommend going with the 180. However, I would definitely NOT recommend going any lower than 180. Plus, I doubt that you'll notice very much difference in actual running temperature with the 180. A thermostat only controls the LOWEST temperature that an engine will run at (except, of course, for the warm-up period), not the highest. I doubt that there are very many operating conditions that your cooling system will be able to maintain a 180 degree temperature unless you drive it in very cold ambient temperature or long, downhill grades in the summer.
    • Gary G.
      • March 1, 2001
      • 47
      Thanks Joe.
