High Pressure In Gas Tank - NCRS Discussion Boards
  • John M.
    Infrequent User
    • February 25, 2008
    • 16
    My '85 seems to have a lot of pressure in the fuel tank. When I go to remove the cap, air escapes for a good 10 seconds and I really have to hold the cap. I don't know if this is normal, as my '74 has no pressure. I have the factory service manual, but it seems pretty vague. I've replaced the vapor canister, the vacuum valve, and the rubber hoses. How would I check the purge canister solenoid. Any suggestions would be appreciated.
  • Jim T.
    • March 1, 1993
    • 5351
    Re: High Pressure In Gas Tank
    My 70 and my 85 retain a good amount of pressure that is released when I remove the gas cap. They both have sealed gas caps that work.
    • Pierre J.
      • July 31, 2000
      • 193
      Just make sure you're not smoking when you remove the cap!!!
      • John M.
        Infrequent User
        • February 25, 2008
        • 16
        Thanks for the responses, it looks like the valve is stuck.
