Can anyone help me with the wiring, I cannot figure out where the red wire goes from the ignitor II? Also what to do with the wires on the ballast resistor? HELP! DUTCH
to the top of the resistor? Then just use a single wire to go from the top of the resistor, over to the positive terminal of the flamethrower? I am just concerned about that single pink wire that is already connected to the top of my resistor? Could someone help me with my confusion? thanks DUTCH
r, and a combined pink-black wire at the bottom of the resistor, which would be the ignition wire, which I should move to the top of the resistor. Also I should run the red ignitor II wire to the top of the resistor where all the other 4 wires are connected. According to every ones feedback, I should take all 5 wires and put them on the top of the resistor, and then run a wire also from the top of the resistor, back over to the positive terminal of the flamethrower. Sounds like alot of wires on the top of the resistor. Is this plan correct? This probably is not as confusing as it sounds. thanks for any feedback , DUTCH
