c3 steering box - NCRS Discussion Boards
c3 steering box
  • Graeme B.
    • October 23, 2007
    • 213
    c3 steering box
    Could someone tell me if the mark on the end of the worm gear should be at the 12 oclock position with the steering box centered ? Thanks,Graeme.
  • Tom L.
    • May 7, 2007
    • 438
    Re: c3 steering box
    Duke Williams wrote a terrific paper on this topic. I followed it when I rebuilt my own steering box. I have it, but it's in .MDI format and I can't attach it. Maybe someone can point to where it can be found online.
    • Robert M.
      • June 30, 1992
      • 120
      Re: c3 steering box
      Dukes Steering box paper can be found here. I read through just it this morning.
      http://www.lbfun.com/warehouse/tech_...%20Rebuild.pdf
      • Graeme B.
        • October 23, 2007
        • 213
        Re: c3 steering box
        Thanks Tom and Robert. I read that excellent article but it didn't mention the chisel mark. Cheers,Graeme.
        • Robert M.
          • June 30, 1992
          • 120
          Re: c3 steering box
          Then try the Jim Shea page, http://jimshea.corvettefaq.com/?page_id=4
          or wait for Jim Shea himself to answer the question.
          • Jim S.
            • August 31, 2001
            • 730
            Re: c3 steering box
            You didn't mention what year C3. All C3s (except 1968 and early 69) had a flat machined on the input shaft. That flat is always at 12 o'clock when the gear is right on center.
            The early C3s had an input shaft that was full round (no flat). I didn't know that there was a mark on the end of the early shafts.
            The way to determine the on center position for the early C3s is to rotate the gear full lock to full lock. Count the exact number of turns. (Should be 3.6.) Now go to full lock and come back exactly 1/2 the number of full turns. (Should be 1.8). You now have set the gear exactly on center.
            Jim
            • Graeme B.
              • October 23, 2007
              • 213
              Re: c3 steering box
              Thanks Jim, I'll go and do that right now. Cheers,Graeme.P.S.-Yes '69 round shaft.
              • Chris W.
                • September 30, 1982
                • 49
                Re: c3 steering box
                I think it should have a mark on the end of the shaft which should be straight up, 12 oclock position, when straight ahead. My '65 does and I think all the "round shaft" boxes were the same.
                Chris
