Unidentified Tilt/Tele spring? - NCRS Discussion Boards
  • Tom L.
    • May 7, 2007
    • 438
    I took my column apart several months ago to rebuild and paint. I'm just putting it back together today, but I ran into a snag. I have a spare part. The spring to the left of the column in the picture was in my parts box, but not in my 50 disassembly pictures or the parts blow-up in the service manual. Does anyone know where this goes? Thanks.
  • Tom L.
    • May 7, 2007
    • 438
    Re: Unidentified Tilt/Tele spring?
    I think I figured it out.
    I think the spring was part of a lower column rebuild kit that I bought from Paragon. I think that the spring is used in the bottom of non-tilt columns down near the reverse lock out lever, but is not used in the tilt column.
    Can someone please confirm that this spring is not used in a tilt column? Thanks again.
    • Kurt B.
      • July 31, 1996
      • 971
      My 68 Telescope column has a similar spring behind and directly under the horn button assembly at the top of the wheel.
      Kurt
      • Jim S.
        • August 31, 2001
        • 730
        The upper end of the shift tube in the 1969 through 1976 Corvette standard (non-adjustable) steering column was a slip fit into the shift bowl. It required a spring on the lower end to push on the shift tube and keep it preloaded up into the bowl.
        The 1969 through 1976 Corvette T&T steering column had a shift tube that was a press fit into the shift bowl so it didn't require a spring.
        I don't know why the difference in design between the two types of columns.
        Jim
